It looks like you are trying to set your material origin to a place the X-axis can’t go. In your software for your project, make sure you’ve specified the lower left corner as the job origin. After you home the machine, before you move any axis, make sure your material’s bottom left corner is behind and to the right of wherever your bit is as you look from the front of the machine. Then go ahead with your probe.
