Z axis probing error
Trying to probe my z axis, and I am getting an error. Z axis position ######, is less than minimum soft limit. this was on startup no jobs ran prior to this message today, restarted got same error. Process same as normal, not sure why the error is displaying.
Have you tried to rehome your Z-axis separately?
Ive had that happen before and i moved my z up a little and rehomed and it was ok.
Is your job setup to the material or the spoilboard?
appreciate the reply but it was self induced. I tried to adjust my z mounting position which caused the issue. It was ok when having material on the spoilboard, but trying to resurface the spoilboard this issue showed up. Thanks
