Z Probing Problem
I keep getting an error while trying to probe my z axis. It says “Z Axis position 137.25 is less than the minimum soft limit -133mm.” I had previously zeroed it successfully and ran a flattening program which I paused to adjust dust boot. Upon restarting program it did not return to the position it was paused at, and that’s when it south. I turned off controller then on, rehomed the X,Y, and using the probing block, this was the result - Now it won’t probe for Z.
Any suggestions
I’m a rookie…
Blockquote
