Started machine an hit home machine on start up screen. All good xyz all homed as usual. Hit probe xyz to set up new carve , all went well until I hit th probing complete, then an error message came up saying x is under limits. How can I fix this? Thank you for any help.
You might need to move the materials in whatever direction is under limit. Example: If you have the Woodworker (32x32) and your material is 28 wide, then you can’t locate it beyond 3.99 inches from left home position, or it can’t reach far enough to the right end of X axis.
Does this make sense?
Hey Dale,
