I have been having an issue during my tool change which comes up as a Estopped Switch not found error after trying to Z probe for my second tool path. A few people have mentioned the same issue but no one has really offered a solution. Apparently the issue is with the M6 command in the Gcode but I don’t know how to get rid of that. You would certainly have to reset the Z axix on a tool change as the bit height will have changed so the command to reprobe the Z axis makes sense but again for some reason causes an error. What is the solution?
