FAQ Question - Curly Cable
Hey @OnefinityCNC - you posted this recently:
I simply don’t understand what you mean.
1 - Are you saying ripping out the coiled wire to the Z motor will cause it to not work properly?
2 - Are you saying rewriting the Z (and maybe X/Y) motors will cause them to not work properly?
When you say “cross” – you are not specific or detailed. Is there some sort of impedance or EMI issue you are correcting that can be inadvertently undone by introducing a custom drag chain?
Super confused by the post. Please advise.
After just experiencing this last night, while wiring up my other controller, I think basically what they’re saying is - don’t trust the color codes on the wires, as they don’t match those coming off the motor (if you look at the motor reference specs).
In the end, it’s all quite easy to fix, if you do goof, simply swap any pair of coil wires. You can check which pairs of wires are in the same coil with an ohm meter. Any two wires that have a measurable resistance across them - belong to the same pair. When wiring up, if the motor moves in the wrong direction, simply swap any pair of wires to reverse the direction.
Ah, OK. Cross the colors. I was thinking cross the wires - as a bundle. Maybe I need to let all the Ghost Busters references go…let it go, let it go… :wink:
…don’t cross the streams! :laughing:
