Feeds and speeds for cutting HDPE
Sharing my experience in case it helps someone else.
Material: HDPE - “King StarBoard Marine Board” brand in 0.490" thickness
Operations: full thickness slotting, full thickness pocketing
Here are the feeds and speeds that worked for me:
0.125" dia conventional upcut endmill, two flute (an single flute O-flute is often recommended but I didn’t have one of those)
100 IPM @ 0.08" DOC (probably could go both faster AND deeper - provided can clear chips)
spindle speed ~11K rpm (even slower normally better with HDPE, but it seemed like I had a harmonic around 10K)
plunge cuts at 30 IPM with full retract (to clear chips; probably could plunge faster)
​conventional cut (NOT climb cut)
NO FINISH cut necessary to achieve good surface
…and the big secret: blow compressed air at the bit to aggressively clear chips. A dust shroud was simply inadequate for clearing chips in the slots, leading to chatter and chip rewelding onto the base material.
-Mark
Continuing the discussion from Feeds and speeds for cutting HDPE:
Hello Mark.
Merv Bowman, Woodstock, Ontario here.
I have been cutting 2.5" Z tactile reliefs using various woods. The most troubling issue is of course warping after removing so much material from 3" boards.
I am considering using 3" slabs of HDPE. Any thoughts you may have on this would be appreciated. These reliefs are being created for the blind/low-vision community, thus smooth finish is essential. I am interested to hear how you rigged up your compressed air system? My cuts are on 20 X 24" slabs thus my cut times are anywhere from 18 to 28 hours depending upon detail.
Hi Merv, great project. HDPE doesn’t warp from moisture like wood, but thick slabs can hold internal stress and bow when you remove a lot from one side. Taking a light skim off both faces before you set up the carve helps release that stress evenly. If a finished piece does bow a bit, setting it in the sun on a flat surface with some weight on it can help ease it back.
For roughing, a single-flute O-flute upcut clears plastic chips best. Run lower RPM (12–16k) with a decent feed so you’re making chips, not melting it. Air blast or a strong vac helps a lot. Finish with a ball nose at a small stepover. If any fuzz is left, a quick pass with a heat gun cleans it up without hand sanding.
