I would look at this post: Testing and tuning OF for accuracy - #15 by cyberreefguru - but instead of using “eyeballs” on a ruler to see if the movement is correct, machine a pocket the largest size your accurate caliper can measure, and make adjustments from there. You should be able to adjust the distance/step setting to get this dialed in a little closer.
MikeH
(Michael Hentges)
15
Related topics
| Topic | Replies | Views | Activity | |
| Help: Test aluminium part is oversized | 10 | 918 | August 2, 2021 | |
| All items created are .015" too small | 61 | 3261 | April 24, 2023 | |
| Testing and tuning OF for accuracy | 55 | 10675 | January 17, 2023 | |
| Received my OF, let the measurements begin! | 12 | 1481 | November 17, 2021 | |
| Pockets are wider than designed | 20 | 606 | September 13, 2024 |
