Folks, what is the latest thinking about flash drive specs that are necessary for uploading a Onefinity job on a PC and downloading it to the black box controller? Thanks, Mark
Maso says to use a name brand drive and format it correctly. Here is how to do that . . .Start a command line running as Admin (in the search box, type command line)
A Command Prompt box appears, in that type the following
diskpart
list disk
(find your external disk number - will put example disk 2)
select disk 2
clean
convert mbr
create partition primary
select partition 1
active
format fs=fat32 quick
assign
exit
That will format the drive to work with Masso.
He does not have a Masso.
Yes, jn Buildbotics controller, sorry, should have made that clear. Also, I will need to transfer files in Vcarve Pro Version 12. What size flash drive?
Thanks, Jim, for bringing this up.
Mark
For Onefinity CNC job uploads, a flash drive with a capacity of 8GB or more should suffice, given that CNC files are typically not very large. It’s recommended to use a USB 3.0 drive for faster data transfer speeds. Ensure it’s formatted to FAT32, as this is usually compatible with most controllers. Reliable brands like SanDisk or Kingston might offer better longevity and performance. Also, regularly check for firmware updates for your Onefinity controller to ensure compatibility.
Thanks, Dennis, thats what I was looking for.
Mark
