Fusion 360 Setup
I’d love to see a video or document on setting up Fusion 360 for using the Elite.
This may be of interest as a starting point - Create a Custom Machine Configuration in Fusion 360 for Hobbyist CNC | Shapeoko, X-Carve, LongMill - YouTube
Thanks! That was the first video I watched on the topic. Kevin’s videos are excellent.
I’m not sure if or how the dual Y axis steppers affect the configuration. I wonder if more configuration is required than selecting a 3 axis machine to modify like in this video.
What is your main goal for wanting to configure the machine?
I initially set up my Woodworker, but to be honest I never select it in my F360 CAM.
Great question! I haven’t actually used any G-code produced by Fusion’s CAM yet. I’m not sure what adding the machine and selecting it actually gets me other than a visual of the machine footprint. My main goal is to have Fusion 360 produce G-code that will work on the Elite. I do have a rotary that I’m planning to attach as well. I’d assumed that Fusion would need to know about the machine’s configuration in order to properly generate G-code for it. Maybe that’s a bad assumption?
For me I was more concerned about the tool information being accurate, and also appropriate for my machine - the 2.2Kw spindle is not terribly powerful, and the Woodworker has a fair amount of flex compared to other ‘mill like’ machines - so filling in feeds and speeds for the tools/tool paths are important. I also made/modeled my ISO tool holders (I couldn’t find them available in a F360 database), and added these to my tools, so collisions could be detected should I make an error in my CAM. I plan to make smaller items, so having the machine boundaries known by F360 is less important to me as well.
You don’t need a machine in Fusion at all. The G-Code compiler you select is the crux of the matter insofar as code configuration is concerned.
Ok. I have configured the Masso post processor. However, I’m not sure I have it all set correctly. Is there documentation for how to set that up with the Elite?
Care to share the Masso settings you found most impactful? Thanks
Did you find any documentation? or did you figure out what to use for machine and post in fusion 360? Please share your experience. Thanks.
