I’ve made some fixes to eliminate the errors in the Fusion post-processor for the WCS not specified and the unreachable code for drilling operations.
I added an additional safe retract mode to just raise the Z height with G53 instead of also sending it to the XY home. This works a lot better for my workflow, just raise the Z at the end of the job.
I also reordered the spindle shutdown after the final move so you don’t wait for it before the move.
Also fixed a bug that ignores the “Use M6” setting.
This has not been reviewed or endorsed by Onefinity or its suppliers such as @RTCNC so use at your own risk. I don’t have a tool changer so M6 isn’t something relevant to me. If M6 is required it would be best to remove the “Use M6” setting instead.
Hopefully some of this can be used in the next official release. To use, import RealTimeCNC-RTSX_V2.dsunds.cps into your Fusion post-processor library and select it for your post.
changes.txt (8.6 KB)
RealTimeCNC-RTSX_V2.dsunds.patch.txt (12.0 KB)
RealTimeCNC-RTSX_V2.dsunds.cps (86.5 KB)
