Help with MASSO Z Offset
I hate to ask, but I’ve looked for the correct info on what these Z Offset does for me and I can’t find anything. What I’ve noticed is that some of the tools have a Z Offset and some don’t. I’ve tried to go in and zero out those numbers (when I switched tool numbering) but it won’t let me change it. I’m having some issues with my Z cutting deeper than it should and I’m wondering if this offset could be the cause? Any help would be appreciated. Also, I use a tool setter and touch probe if that makes any difference.
If you use a tool setter or ATC this field will be populated by that device.
Pat
If you do not have an ATC, F4 page isn’t used and you want all lines to be 0 values.
Thank you, I wasn’t aware of that. Do you know how I can zero those out without resetting back to factory settings?
Chief515, did you ever get an answer to zeroing out the Z offset? Care to share?
I think you can just double tap on that tool and zero out the z offset
Jay
