I have the GEN 2 Elite Foreman.
Following Instructions and got up to the HMI Mount Install. The Molts they sent are either too long or something is wrong. The bolts measure 75mm. I’m assuming it was a packing error. Did anyone else get this issue?
I actually had bolts that were a little short for the HMI mount. Contacted support, and they sent the correct size fairly immediately.
I will admit that I ran out of patience and made a trip to the hardware store while I was waiting for delivery…
While I was developing an extension bracket for the Gen 2 machine I noticed these newer machines need some shorter bolts - it makes sense that you got a set that was too long, as the older machines used the longer bolts.
