Homing after a cut
Is there anyway I can set my router to raise up only when finishing a cut? as I’m having difficulty after making a pocket in a tray, I then switch to a 1/4 downcut bit and it rips through the walls of the tray as it lowers first, and vice versa when doing the outside cut first. i just need the router to stay in XY position when finishing a cut and just raise up the Z.
im a newbie so any help would be much appreciated.
thank you
Did you re-zero after the bit change? When you change a bit the last zero reference is not the same as the new bit.
hi woodpecker,
thank you for replying,
yes I did. I just would like it to home the Z axis at its highest point after a cut, if I could establish how to do this I think my problem should be solved. I do not want to start changing settings without being sure what I’m doing.
