1F connection with no touchscreen
Before you start please make sure wifi is turned off in your laptop (as you will be using an ethernet cable)
- Make sure that the emergency stop is disengaged/disabled
1a. If this is a brand new machine you will need to turn the emergency stop to get it to “pop-up” out if it’s stored position during shipping
Connect up the included power cable to the 1F controller
Connect up an ethernet cable with one end plugged into the 1F controller and the other connected to a laptop
Turn on the power switch to the 1F controller and make sure the laptop is powered up to an available desktop view.
4a. You should be able to visually see lights on the ethernet port of the 1F controller and laptop at this point.
Open up a web browser on the laptop and navigate to http://OneFinity.local
This should now provide local based access to your 1F allowing control without a touchscreen.
