I am trying to figure out how to get past the clearance on the Z hieghth with a 65 mm spindle
I am wondering because everyone says that the 80 mm adapter you won’t have that problem is that only with the larger spindle or can I use a 65 mm spindle in their with the plastic adapter enlarge the 65 to an 80 that get the clearance or will it still hit the motor
80mm mount with a 65mm adapter(for now) is what I use. No clearance issues at all.
Thank you sir at the risk of sounding like a nuisance, that is with the 65mm spindle, 80mm adaptor and the 65mm sleeve, I rather ask twice and purchase once…
Correct!
3D printed the adapter myself.
Z20 slider with the 80mm mount, 80x65mm adapter, 65mm air cooled spindle.
Thank you getting the printer fired up…
