Humid climate concerns
All,
Just made my purchase last weekend and anxiously waiting for my Elite Foreman to arrive. I live in Houston area and due to the hot temps down here i’m struggling with what to do about the spindle i need to purchase for it. I plan to go with 80 mm water cooled at the moment for reference.
Do any of you live in hot humid areas where you don’t have a climate controlled shop/garage?
If so, do i need a water cooled spindle and will i need a chiller for the spindle?
What mixture or what fluid are you using for it and why?
Would anyone be willing to show me pictures of their setup so I can visualize how this water cooling will need to be laid out?
I’m planning on getting a kreg table frame building out the table from there or doing it fully custom. All depends on how much time I have to work on it before it arrives.
Thanks for your input.
Alan
I’m in central Florida. I have never needed a water cooled spindle. I do have to resurface my spoilboard once a quarter or so because the humidity impacts the mdf. I can see an advantage for it, but the environment in my garage isn’t a driver for the machine… More important to manage the environment for the operator when it’s 90F and 100%RH.
Alan,
I’m in Houston. You’ll be fine with an air cooled spindle or water cooled spindle without a chiller.
I’m currently using an 80mm Mechatron spindle with a chiller. I went with the water cooled spindle because they’re quieter. Sort of pointless, considering I have a 2hp dust collector beside my cnc, which is far louder than an air cooled spindle.
I was originally planning on buying a large CO2 laser, so I bought a chiller to cool both that and my cnc spindle. I decided I’d rather have a sawstop than a big laser that I’d probably not use, so the chiller is only cooling my spindle. In hindsight, a cheap circulation pump amd a head tank would have been fine for the spindle coolant. Im just using some coolant from auto zone.
Dan
Hey A P,
the advantage of a water-cooled spindle is that the spindle cooling is independent of the spindle speed (rpm). You may even continue to cool the spindle after it was stopped by programming your VFD to do so (if you connect your coolant pump to the appropriate relay output on your VFD). Water cooling means you can always control the temperature ideally, usually you also have an alarm if temperature gets to high (my cooling station allows to trigger an alarm) which you don’t have with an air-cooled spindle.
What coolant to use can be found with the forum search function, e.g. it was discussed here.
You may also search for “chiller” to see what solutions the forum members use.
The disadvantage is you have to deal with “plumbing”. And if you have the Elite drag chain, forget it. As long as you don’t want to lay extra long water hoses with the dust collection hose (what some people did but I don’t recommend), the best solution is to retrofit a >70 mm wide drag chain anyway, which will also allow you to lay better cabling system easily (possibly later) with more upgrade capabilities (you may upgrade to sealing air to prolong spindle life, add spindle LED light ring, camera, workpiece coolant hoses, lubrication hoses, etc.).
Many users here have retrofitted a serious drag chain, you can buy some in the www for the Onefinity, but if you have a 3D printer, you can make one yourself (see example here). You can also buy 3D files to print some yourself or use the 3D files that forum members posted here, or design your own. You just buy the drag chain links as bulk stock with desired length, and aluminium L-profiles, and then 3D-print the parts that attach to the axes.
With an air-cooled spindle, you just have the spindle power cable (see here for how to make one yourself) and that’s it, for a minimal configuration. The fan sits at the end of the spindle axle and runs with the same rpm as the spindle axle. That’s okay for woodworking, because with woodworking you always want high torque at high speed (which is why you throw the hand trim router away which can only deliver one of both, but not both at same time)
However, you may consider that in order to ensure the life and functionality of machines, in regions with increased humidity, the humidity in the room can be regulated. Electronics should be used within a range of 30% to 70% rH, machinery (especially steel) too, and human comfort is best at 40% to 60% rH.
Aiph5u
Question on the drag chain, what length of the chain is needed? 1 meter per x and Y or 2? I was assuming 2 to cover the fold over of the chain and extra links in case something breaks or extra slack is needed.
I was looking at the following: https://www.amazon.com/gp/product/B0BXDDNJQ9/ref=ewc_pr_img_2?smid=A2M49RHWISCA2E&th=1
Thank you for your insight. The information was appreciated.
OT: Just for the record: As the person who introduced drag chains into this thread, I feel responsible to post: That topic goes on here. Readers please follow there.
