Warning: use only if directed by support. Disregard if support did not direct you to this post.
Using this file incorrectly can damage your machine.
32x16x50hybrid.json (12.6 KB)
To install:
Download the above file to a usb stick
insert usb stick to the Onefinity controller.
Boot controller.
Skip Homing.
click the flyout menu
select General (under admin)
click ‘restore’ under configuration on the right side.
Select the file on the usb stick
Click open.
a pop up box should say 'Success, Configuration restored".
Click the green OK button.
Restart from the flyout menu.
Done.
