I need dust collection boot system for 80 mm spindle
Andy,
Would you please share the modifications you made to the suck it dust boot. I would love to follow your lead on this.
Sure. I’ll send you some files and thoughts i may have for doing better.
@Dustydave
Fusion360 Archive format and STL attached.
I have not altered these files so some tweaking to the diameter of the connector to the Suckit Dustboot is necessary(or leave as it to adjust with some painters tape.
In the long run, a magnetic attachment would be great.
The F360 file is a bit rough - I find Lofting in F360 more of an art form than a science; soo a bit hit & miss.
Suckit 4 inch vac adapter v5.f3d (144.7 KB)
DustBoot.stl (297.2 KB)
I forgot to include:
I also created an F360 file for the shield using the SVG provided in one of the Onefinity Support posts and moved the centre cutout. They are not bad 3d printed (which I did before cutting out of polycarbonate) to test that I had imported the file correctly (dimensions on imports can be awkward)
NewShield.zip (17.8 KB)
NewShield.stl (68.6 KB)
Suckit Shield.f3d (1004.6 KB)
