Anyone with a big dust collector hook up that 4" (or greater) to the 1F?
Noob here (to all of Woodworking), so thanks in advance…
If ‘the more chips made, the more CFM is needed’, my question is whether anyone has hooked up a dust collector (as opposed to a vac with its high static pressure/suction)?
I was looking at this big ol’ dustboot (it has a 4" ducting option) and wondering if it got all the chips/dust better (I know it will get all the <= 1 micron ‘fines’ better).
Right now I have an ancient Craftsman shopvac with a Oneida Dust Deputy hooked up to the 1F Suckit Pro with 1.5’ bristles, but was wondering if there’s a better way before I settle on one hose/cord solution mentioned on these boards (like this). I don’t want to order something that holds a 2.5" hose only to end up using 4" from the DC.
Anyone notice the new “Infinite Dust Collection Kit”? Looks like both the Suckit, and a green v2 Suckit that collects from the rear. I wonder if rear collection is more successful?
I’m still waiting for my 1F but my plan is to use a 1hp DC. The only issue I can see with that dust boot is that the front edge will be hanging off the front of the work piece so it may not work well when the router is working near the front edge. If I had the means to make a boot I think I would make it curved to follow the shape of the router or spindle and the other 3 sides square. That would get the suction as close as possible to the router.
I’m thinking of trying one of these I’m going to be using a spindle that came with a mounting bracket that is useless for the 1F. So I was thinking of adding a clip to hold a 4" hose that mounts to the clamp. Then use the clamp at the top of the spindle. That way when I remove the front of the boot for a bit change I can easily pop the hose out of the clip and get it well out of the way without any tools.
I have a large central DC and I have been unsatisfied with the dust removal through the standard dust boot.
Nice! A good boot is great!
I have a 4" dust boot that can be 3d printed. I now have versions for both 65mm and 80mm spindles. Here are the 2 versions side-by-side.
The files are on Thingiverse - 65mm: OneFinity 4-inch Dust Boot by gopher5 - Thingiverse 80mm: Thingiverse: Onefinity 4-inch Dust Boot for 80mm spindle by gopher5 - Thingiverse
I also have an Etsy shop if you want to buy one - HentgesWorkshop - Etsy
Dust Boot: how are you finding your dust boot? I’m finding the suckit dust system a bit wanting and a little fragile (or I’m heavy-handed :blush:).
It looks like the one you had in mind in this thread connects directly to the spindle rather than the z slider. How are you find that when the spindle moves up n down, different length bits? I assume you have to adjust its position on the spindle. Is that the case? Cheers.
Here’s my Amazon one. Occasionally I will slide it up or down on the spindle depending on bit length but for the most part this is where I leave it. My surfacing bit is much larger than the ones people use with their router and sticks down lower than most bits so I move it down. The end of the brush is about even with the but but they will bend out of the way if I’m making a deep cut. I like it because the brush is just around the bit. This means there’s no loosing suction because you are working near the front or rear edge of the piece.
It’s made for a 100mm spindle but comes with an adapter ring. I had to modify the back since I didn’t have access to a 3d printer make an offset adapter.
Great pictures, thank you. I’m going to give it a go.
Jared, you’re saying the Wen impeller works on the Harbor Freight 1HP dust collector? That’s interesting for sure. I don’t know if I’ll do the swap because I only have a singe 10ft run and get plenty of suction. Decent upgrade to keep in mind though.
saying that part works on the 2hp unit. I cutout the opening and increased to 6” too. It’s only 4” after the overall opening because I couldn’t find 5 or 6” pvc easily, whereas the 4” was readily available(yes I have it grounded well).
Only on the 2hp not 1 hp
At the moment, I’m bogged down doing something I thought I would not need to do; calibrating the CNC to improve accuracy if x travel.
I’ll give both dust boot options some thought; I’m keen to improve my dust removal after doing a bit of MDF routing; awful stuff.
At least on my 1HP dust collector the biggest issue was the plastic restrictor on the input and output of the fan. Unlike a thin metal one the plastic grid is so think that it created a huge restriction. I removed both of them and now it has more than enough suction for the 1F.
For those with a 2HP dust collector pulling over 1500 CFM, what combo of hose, collector, mount have you found that works well? I keep trying different connectors and mounts, but I am still struggling with a good solution because my dust collector hose pulls everything up (and out of whack to the point that it doesn’t work or stay mounted).
I have a 4 inch Fulton hose running from dust collector to the CNC.
Wowsa! That is a ton of CFM. Must be a Binford 5000! My cabinet saw works well with 400 CFM, and my Powermatic planer (which generates a couple of 55 gallon barrels of chips on a busy week) uses 650. At 1500 CFM, your DC seems like the Jolly Green Giant trying to drink an entire lake through a coffee stirrer straw.
Unless you can adjust the CFM on your DC, you might have a problem that doesn’t have a straightforward answer. One thought is to put a “Y” at the DC outlet (at 2HP, it may have come with one to go from 5" or 6" to 4") and run one line to your OF and using a grate cover on the other, just leave it open. That should cut the force, now focused solely on the OF and putting considerable strain on the hose, considerably.
Let us know how things progress?
Jim
Howdy!
I have a 4" boot really really like it! I’m hooked up to a 4" from a 2hp Grizzly dust collector and it worked awesome! I only did about 26 minutes of cutting in 3/4" Birch but there was no saw dust anywhere outside of the boot. I am using a 80mm spindle. There was some buildup around the spindle itself but it was very minor. I just used a thin rope from the ceiling to suspend the hose above the CNC and everything was perfect. The image below was after I moved the spindle out of the way. No dust!
That We The People is Bad ASS! Awesome Work!
-Alex
Thanks! I’m selling them locally at fairs and online :slight_smile:
5hp Clearvue. I’ve been trying to figure out an alternative. As I’d hate to run it for 4 hours on something big. There are plenty of 1hp wall hung I’d like to give a shot. Something quiet
