Does anyone know if it is possible to import a .dwg or .dxf with solids from AutoCAD into VCarve Pro? I want to take a 3D model from AutoCAD and machine it using VCarve Pro, but I dont know if that is possible.
Thanks for your help.
Export to Obj format. A quick autocad export google should help.
You can export an .stl as well. Set the facetres variable to 10 before you export.
