Just wondering is it possible for the Z axis to lose position over time or after the machine has been pause? if this happen what would be the potential cause?
Henry
Henry
I would say unlikely, but possible nevertheless. The Z could be subject to downward creep based on the weight of the assembly, without power to the motor. Much the same way you can manually move X & Y with no motor power, the z has the weight working to drive it downward.
Yes, it is possible.
The controller estimates the position from the moves but the motors are not servos so there is no feedback. If a move does not perform as planned, then an axis would loose position.
Prior to firmware 1.0.8, this could happen when the G-code was requesting moves faster than the machine could achieve. I also had the problem on the Y axis with a badly placed wrench that blocked a move. It lost position but carried on milling… in the wrong position.
I can imagine that hard stock that does not machine as quickly as planned could cause the Z axis to loose its position, although I never had the problem myself.
"Prior to firmware 1.0.8, this could happen when the G-code was requesting moves faster than the machine could achieve. "
Is there a thread talking about this? I have had this issue happen several times over the last few months losing position and then continuing on in new position but have not seen any real solution found. I looked for loose parts or bent screws but could not find any reason for it.
I have not seen it in a single thread.
The firmware 1.0.8 change log discusses the controller loosing steps:
@blaghislain explained the problem with the firmware and fast moves, after I had requested help with Fusion 360 CAM.
If you google servo vs stepper, you will see that the 1F controller has no feedback from the motors.
Thanks for the info. I am using carveco so I am not sure if my issues are the same. It has only happened a few times over the last few months but each time was during a very long detailed carve for me.
Should not happen if the motors remain powered. Has happened to me after a bone head mistake like probing without the magnet
Or drilling on a screw head. The stepper would have to lose a step for it to get out of sync.
