As the title says.
Curious to find out if the device is considered normally open or normally closed.
I believe it’s normally closed.
This is straight from the Masso documentation
Interesting, the documentation shows a switch that triggers a cycle stop if the primary touch off doesn’t trigger. I don’t think the Onefinity tool setter uses this feature, but it would be nice!
Thanks Mike
I agree. I do not think the over travel switch is connected as the tool setter only has 2 wires.
Any idea if there exists a tool setter that is normally open by default?
Everyone I have found online so far as been normally closed.
