Is there anyone who has installed Airweights slats and the Easy ATC?
I’m looking at ordering the airweights slats for my Journeyman, but I just received my ATC and looking at the instructions it looks like for the QCW mount, it will require the two rightmost slats to move back from the front of the machine. Does this mean that it’s just not possible to use airweights in those positions while using the ATC (since you can neither cut them down, nor drill new holes in the bottom of them to mount them in the backed up location)? I know 1F is redesigning the QCW mount due to the quality control issues they experienced, maybe it can be designed in a way to not affect usage of airweights?
The Airweights slats have slots that allow for some Y axis adjustment. The slots are for screws that fasten into the spaced holes on the flats of the T-slot table supports.
My guess is that the original QCW mount, and most likely whatever new solution will be delivered, will not have the Easy ATC sitting past the front of the T-track - maybe butting up against it as that would be a handy reference for alignment. So long as the vacuum slats can be fastened such that they do not protrude past the front of the T-track, I feel it should work.
Hopefully someone with this setup can confirm how far back the slats can be fastened.
There are slots on the table top ones, but the slats just look like they have fixed screw holes to me. That’s why I was concerned. See this picture: Onefinity QCW Vacuum Slats – AirWeights
I just found the installation instructions post in the Airweights section on this forum and it does indeed indicate that there are slots. Concerns alleviated. :slight_smile:
