Jtech Laser after firmware update
Just to be clear…
Questions after latest firmware update.
Can I now home the machine upon startup and switching to laser?
No more shutting off dynamic power when low power zeroing?
Under “tools” do I need to set this to jtech when using laser? (I’m not using pin out board)
Are x,y,z, positions remembered if fabricating multiple same parts?
Thanks.
P.s.
On a side note after firmware update:
I noticed my jerk settings remained the same.
Did minimum offset also remain the same?
nobody would like to attempt to answer this?
Can I now home the machine upon startup and switching to laser? YES
No more shutting off dynamic power when low power zeroing? CORRECT
Under “tools” do I need to set this to jtech when using laser? (I’m not using pin out board) When using the Laser, select Jtech Laser, When using the makita or vfd, change to makita/vfd.
Are x,y,z, positions remembered if fabricating multiple same parts? It will remain until reboot.
Thank you very much.
