Jtech Laser, Masso - won't turn on through controller but will run from gcode
I have a Masso controller and a Jtech laser. I can’t get the Masso to turn the laser on manually with any power level through the Masso controller.
However, if I load a gcode file into the Masso for the laser, it works just fine.
The trouble is, I can’t set an x and y zero precisely because I can’t turn the laser on with low power to set it.
Clearly everything is set up correctly because I can run jobs with the laser just fine. But if I give it a sXX m3 command, the yellow laser button comes on, the controller states that the laser is on, but I get nothing.
This is a new problem. With no changes to wiring or configuration, I was using the laser without issue for the past several years.
Any suggestions?
I know this is an old post but hopefully can help someone out with a similar issue
I just upgraded to 5.13 and am having the same issue with m3 & the GUI “laser” button not firing the laser manually when in tool 111. Reading a bit on masso’s site m4 is listed to “laser on immediate” while m3 fires “laser output enabled with motion” I’m guessing this changed between my last version (5.10 I think) and 5.13
The odd thing is the laser on button must still be using an m3 because it highlights but does not turn the laser on till there is x-y movement (apparently via g-code as jogging it with an m3 on does not seem to turn it on either)
Thank you. This allowed me to get my new laser to work from Masso MDI as the M3 command wouldn’t work even with putting a G1 in front of the line. M4 works.
