Just setting up my x-50 woodworker and the monitor won’t display. The blue splash screen shows then it says no signal and shuts off. Any suggestions??
With limited Info, I have to suggest some oblivious thoughts; HDMI plugged in, power cable in the correct USB c slot (the one with the lightning bolt on the screen), controller switched on and ‘humming’?
Controller is on but I do not hear a hum of any sort. No fan running
Double and triple check the e-stop, many people have not pulled it up hard with a twist to get it re-engaged correctly.
Hmmm, I think the fan always kicks in, does on mine. It’s quite noisy as fans go. Check your power supply. Failing that ping onefinity support.
Thank you very much the emergency release was not fully released
