Laser pointer mount
Anyone know of a laser pointer attachment so I can align my bits with an exact point on my project? Thanks in advance.
If you have the JTech laser you can fire a direct no burn focused beam under MDI. There are steps to follow for this to happen.
You can get a couple of these.
https://www.ebay.com/itm/Focusable-830nm-300mW-Infrared-Laser-Dot-Module-with-Adapter-with-Bracket-/261209328811?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l49286&mkrid=711-127632-2357-0
They’re similar to what I put on my CNC plasma. You’ll need to get rid of the bottom plate and perhaps tap a hole directly into the spindle mount or fab up a 3D printed part that you can mount the adjustable arm to.
Or if you want to fab up a full setup here’s a source for just laser pointers you could use.
https://www.amazon.ca/WayinTop-Adjustable-Positioning-Sighting-Telescope/dp/B07ZNKTCLQ/ref=sr_1_3?crid=29QEJ14YFZPS2&dchild=1&keywords=laser+line+pointer&qid=1607011638&sprefix=laser+line%2Caps%2C181&sr=8-3&ref_=d6k_applink_bb_marketplace
In either case you’ll need a small battery source (I’d go with a couple of small 3V lithium coin cells & mount it on the Z carriage.
Thank you guys. I’ll do some more research into it. Just looking to mount a dot laser so I can align it with a specific starting point on projects.
How do you plan to do that? The dot laser isn’t going to line up with the Jtech laser.
Do you have a 3D Printer?
Nope i don’t have a 3d printer…
Its not for a laser. It’s so I can align my router up with specific points of a project…
