Long Reach 1/4 Endmill Recommendations
Hey yall,
I’m in need of a bit that can reach down through 2" material. The material is White Ash.
Wondering if anyone has used 1/4" long reach endmills before and has some suggestions.
Thanks!
ALSO- would anyone mind sharing their feeds and speeds they use on a 3/4 bowl bit through hard wood? Carveco has it set as 40 ipm at .125 doc, but I feel it can go much faster.
Plunge bits or slot bits are normally what I’ve seen the longer straight flute bits called. You may have luck searching for that nomenclature.
Any luck with your question? I actually have the same one except I’m cutting through 2" cedar
I literally just picked up my Journeyman a week ago… still getting table built… but this is the bit that I have in my amazon basket currently. Once I have been up and running it is on my list to purchase. I have a project in mind that involves some 4x4’s.
I’m not sure on the +200 ipm while going .25 down… but I am sure I’ll find out… eventually :slight_smile:
I have one of these:
I’ve used it on mahogany and maple, 100 ipm at 18000. Works fine.
I own this SPE bit, and I do find it a tad intimidating. I keep my cutting depths at around .125 and IPM at 100 or less. I do not get clean finished edges with it, but my goal for this bit is to make my cut, and be happy I have a piece I can clean up with sandpaper. Pay close attention to your work hold down, as it will put more pressure on your work piece. I sometimes start my toolpath and go hide behind the lawnmower until the path is complete :joy:
LOL… I can imagine myself doing that at the beginning too.
I have one of these.
