Manual Tool Changes with the RapidChange ATC
How is everyone keeping track of their manual tool changes with the ATC? I don’t like the 5th manual pocket because all that it would tell you is you need to change to a tool manually. It didn’t tell you which tool you needed to load when doing a carve. What I did to fix this so I would be notified of the correct tool to load was to create additional subroutines for the tools that that are not in the RapidChange ATC. And then I went into the subroutines and changed the generic message to a descriptive name for tool that needed to be loaded.
Not the most elegant solution, especially if you have ton of tools. So, I’m wondering if there is a better way for this?
