Manually changing bits
This may be something that has been discussed already and if so, please feel free to direct me to that post. I am new to using a CNC and have the elite journeyman. The issue I’m running into is when I go to change bits. It will stop and prompt me to change the bit but won’t raise up the router. I have to manually raise it and once changed, it doesn’t prompt me to probe the Z axis. I manually lower it back down but when it starts to cut again, the height of the bit is not where it should be. How do I go about adjusting the settings to avoid this issue in the future?
Its in the F1 screen under tool changer, you the all 3 axis for tool change position there.
Sorry it should read " you set all 3 Axis there"
That did the trick. Thanks for the help.
