MASSO 5.10 and Easy ATC setup
Has anyone seen any setup information for the Easy ATC when using MASSO firmware 5.10? I am seeing conflicting info and want to make sure I set everything up correctly. It is my understanding that the sub-processes are not required on 5.10. Is that correct?
There are two methods:
  1. our method that’s in the manual that can be done on any firmware. This method with subrutines is currently prefered by us and rapidchange.
  2. using massos built in rapidchange support. It’s limiting, so we don’t recommend it at this time.
If you need some help holler. I just set mine up and had lots of questions as well.
What are the limitations you reference when using ATC support with V5.10?
Follow up question. I already upgraded to V5.10. Can I still utilize the subroutine method when I setup the ATC?
EASY ATC question- I have had an Elite Foreman for 4 +years with minimal problems. I purchased an Easy ATC and am in the process of installation. I used OneFinity set up procedure as printed, I think. My first problem is every time I turn the machine on and home it the steps use to be- Z then X then Y. Now after the Y is goes to the ATC and touches off the Tool Setter and stays above the Tool Setter. I have seen others with my same setup on You Tube University and it homes properly. What did I miss? More questions to come…
