Masso Rapidchange ATC setup files (Carveco, Vectric, SVG)
These files compliment our friend @mitzpellic Setup Video:
FILES:
VECTRIC:
Surface mount Vectric.crv (956.5 KB)
CARVECO:
ATC Y spoilboard mounting.art (3.7 MB)
SVG (Right click, save as .svg):
Where do I find all the subroutine shown in the video. All I have is the Z axis and 600.nc
The subroutines are generated using the WebUI, after all the parameters have been filled in and saved. I believe Don has updated the webpage. There is a Macros section top right with a dropdown menu and COPY button. Select the macro/subroutine you want and press COPY. It will be saved to your PC clipboard.
So far all I get to download is a Zxis test along with a 600.nc g code
I believe the other macros become available after you use the Z height obtained and using it to fill in the relevant parameter section(s).
It’s not a file that you will load. In the rapid change subroutines, there a macro that’s called tool change test
