I have made an error when updating the Masso link software and deleted the machine setting file. I attach my back-up file of the latest settings, that I have put into the controller.
Unfortunately, I am now getting motor errors and hard limit errors, which I never experienced previously.
Is it possible for someone to look at the file and either correct my errors or provide me with a file that will work for the basic setting and I would then correct for my file and reinstall the ATC and Probes etc.
Many thanks in advance for your support.
MASSO G3 Touch
Serial No: G3-30991
Hardware: v3.09
Core: v2.07
Software: 5-Axis, v5.13
Settings file format: v2.40
==========General Settings==========
- Machine units: Inch
- Machine bed orientation: Standard
- Load ‘autoload.nc’ on power up:
- Disable Soft Limits:
- Disable Hard Limits:
- Enable cycle start on door close:
- Limit maximum feedrate:
==========Homing Settings==========
Seq 1: X: 0 Y: 0 Z: 1 A: 0 B: 0
Seq 2: X: 1 Y: 0 Z: 0 A: 0 B: 0
Seq 3: X: 0 Y: 1 Z: 0 A: 0 B: 0
Seq 4: X: 0 Y: 0 Z: 0 A: 0 B: 0
Seq 5: X: 0 Y: 0 Z: 0 A: 0 B: 0
X-Axis Direction Invert: Ticked
Y-Axis Direction Invert: Ticked
Z-Axis Direction Invert:
A-Axis Direction Invert:
B-Axis Direction Invert: Ticked
Homing Feedrate: 40
X-Axis Sensor Pull-Off: 0.040000
Y-Axis Sensor Pull-Off: 0.040000
Z-Axis Sensor Pull-Off: 0.040000
A-Axis Sensor Pull-Off: 0.040000
B-Axis Sensor Pull-Off: 0.040000
X-Axis Position After Homing: 0.000000
Y-Axis Position After Homing: 0.000000
Z-Axis Position After Homing: 0.000000
A-Axis Position After Homing: 0.000000
B-Axis Position After Homing: 0.000000
Request Home on startup: Ticked
Request Home after E-Stop press: Ticked
==========Spindle Settings==========
Encoder (Pulses per revolution): 2000
Spindle Control Method: VFD (0~10v)
Spindle RPM at 10 volts: 24000
Spin UP delay (milliseconds): 6000
Spin DOWN delay (milliseconds): 6000
==========Lubrication Settings==========
- Lubricate after: 0(hr) & 10(min)
- Lubricate for: 0(min) & 3(sec)
==========Tool Changer==========
Tool changer in use: 1: Manual Tool Change
Tool setter air blast time (ms): 0
=============X-Axis=============
- Motor: Distance per revolution: 0.629920
- Drive: Pulses per revolution: 2000.000000
- Maximum Feedrate: 600.000671
- Acceleration: 19.685221
- Travel Minimum: 0.000000
- Travel Maximum: 48.031437
- Backlash: 0.000000
- Direction Invert:
=============Y-Axis=============
- Drive: Pulses per revolution: 400.000000
- Acceleration: 19.685362
- Travel Maximum: 48.374744
- Direction Invert: Ticked
=============Z-Axis=============
- Motor: Distance per revolution: 0.393700
- Maximum Feedrate: 300.000366
- Acceleration: 19.685122
- Travel Minimum: -6.299203
- Travel Maximum: 0.000000
- Direction Invert:
=============A-Axis=============
- Motor: Distance per revolution: 360.000000
- Drive: Pulses per revolution: 14000.000000
- Maximum Feedrate: 4320.000000
- Acceleration: 2000.000000
- Travel Minimum: -720.000000
- Travel Maximum: 720.000000
- Angular Axis: Ticked
=============B-Axis=============
- Slaved to Y axis
- Direction Invert:
==========Auto Tool Zero Settings==========
Only auto tool zero when manually requested:
Tool setter X position: 0.000000
Tool setter X enable:
Tool setter Y position: 0.000000
Tool setter Y enable:
Z safe distance to tool setter: 0.000000
Tool zero feedrate: 20.000011
Tool number to skip: 5
==========Multi Head Settings==========
Dry Run: Disabled
Multi Spindle-1 (T101): Disabled
Multi Spindle-2 (T102): Disabled
Multi Spindle-3 (T103): Disabled
Multi Spindle-4 (T104): Disabled
Laser Engraving/Cutting (T111): Disabled
Plasma Torch (T112): Disabled
Oxy Torch (T113): Disabled
WaterJet (T114): Disabled
Scribe Tool (T115): Disabled
Pen 1 (T116): Disabled
Pen 2 (T117): Disabled
Camera (T118): Disabled
==========INPUTS==========
EStop: EStop, Invert: No
Encoder: Signal - A, Invert: No
Encoder: Signal - B, Invert: No
Encoder: Index, Invert: No
MPG: Dial Signal - A, Invert: No
MPG: Dial Signal - B, Invert: No
MPG: Select X, Invert: No
MPG: Select Y, Invert: No
MPG: Select Z, Invert: No
MPG: Select A, Invert: No
MPG: Select B, Invert: No
MPG: Resolution 1, Invert: No
MPG: Resolution 2, Invert: No
MPG: Resolution 3, Invert: No
Analog: Input 1, Invert:
Analog: Input 2, Invert:
Input 11: Tool Setter, Invert: No
Input 12: Touch Probe, Invert: No
Input 13: X - Home Sensor, Invert: No
Input 14: Y - Home Sensor, Invert: No
Input 15: B - Home Sensor, Invert: No
Input 16: Z - Home Sensor, Invert: No
Input 19: X-Axis Motor Alarm, Invert: No
Input 20: Y-Axis Motor Alarm, Invert: No
Input 21: Z-Axis Motor Alarm, Invert: No
Input 22: B-Axis Motor Alarm, Invert: No
==========OUTPUTS==========
Spindle: CW, Invert: No
Spindle: CCW, Invert: No
Output 11: Laser-Engraving (PWM), Invert: No
Output 12: Coolant Flood, Invert: No
==========TOOLS DATA==========
Tool-1, Slot: 1, 3.125 Jenny, Z Offset: -5.137208, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-2, Slot: 2, 3.125 Vbit, Z Offset: -3.242915, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-3, Slot: 3, 6.35 Upcut, Z Offset: -2.715946, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-4, Slot: 4, 6.35 Dcut, Z Offset: -5.479530, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-5, Slot: 5, manual, Z Offset: -3.473624, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-6, Slot: , , Z Offset: -5.353350, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-7, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-8, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-9, Slot: , , Z Offset: -4.116341, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-10, Slot: , , Z Offset: -4.653349, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-11, Slot: , 90 deg. V, Z Offset: 0.000000, Tool Dia: 0.375000, Tool Dia wear 0.000000
Tool-12, Slot: , , Z Offset: -4.950790, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-13, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-14, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-15, Slot: , , Z Offset: -4.489570, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-16, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-17, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-18, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-19, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-20, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-21, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-22, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-23, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-24, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-25, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-26, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-27, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-28, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-29, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-30, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-31, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-32, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-33, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-34, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-35, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-36, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-37, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-38, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-39, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-40, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-41, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-42, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-43, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-44, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-45, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-46, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-47, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-48, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-49, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-50, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-51, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-52, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-53, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-54, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-55, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-56, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-57, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-58, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-59, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-60, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-61, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-62, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-63, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-64, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-65, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-66, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-67, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-68, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-69, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-70, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-71, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-72, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-73, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-74, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-75, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-76, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-77, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-78, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-79, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-80, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-81, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-82, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-83, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-84, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-85, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-86, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-87, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-88, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-89, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-90, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-91, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-92, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-93, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-94, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-95, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-96, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-97, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-98, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-99, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-100, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-101, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-102, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-103, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-104, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Workoffset - G54:
X: 24.015404
Y: 24.185795
Z: 0.324219
A: 0.000000
Workoffset - G55: Main Fence
X: 1.623517
Y: 3.411547
Z: -1.615946
A: 0.000000
Workoffset - G56:
X: 0.000000
Y: 0.000000
Z: 0.000000
A: 0.000000
Workoffset - G57:
X: 0.000000
Y: 0.000000
Z: 0.000000
A: 0.000000
Workoffset - G58:
X: 0.000000
Y: 0.000000
Z: 0.000000
A: 0.000000
Workoffset - G59:
X: 0.000000
Y: 0.000000
Z: 0.000000
A: 0.000000
Parking: Main
X: 23.622061
Y: 11.811030
Z: 0.000000
A: 0.000000
