Help! Axis distance problems (solved)
Just trying to set up my machine and after homing i try to jog to set my rear screws, the machine only moves a quarter of the way down the axis. This is true for both the x & y axis. I have checked my dip switched and all are set properly. I all so go through the homing process.
Any help would be appreciated.
Can you please provide a copy of you printable settings file.
How does one go about creating that?
The masso says it moved 48+", but it only moved 12 in+/-
You would need to follow the instructions on the page I linked in my earlier response.
Let me know if this is what you are looking for:
MASSO G3 Touch
Serial No: G3-19686
Hardware: v3.07
Core: v2.06
Software: 5-Axis, v5.07
Settings file format: v2.30
==========General Settings==========
  • Machine units: Inch
  • Machine bed orientation: Standard
  • Load ‘autoload.nc’ on power up:
  • Disable Soft Limits: Ticked
  • Disable Hard Limits: Ticked
  • Enable cycle start on door close:
  • Limit maximum feedrate:
==========Homing Settings==========
  • Seq 1: X: 0 Y: 0 Z: 1 A: 0 B: 0
  • Seq 2: X: 1 Y: 0 Z: 0 A: 0 B: 0
  • Seq 3: X: 0 Y: 1 Z: 0 A: 0 B: 1
  • Seq 4: X: 0 Y: 0 Z: 0 A: 0 B: 0
  • Seq 5: X: 0 Y: 0 Z: 0 A: 0 B: 0
  • X-Axis Direction Invert: Ticked
  • Y-Axis Direction Invert: Ticked
  • Z-Axis Direction Invert:
  • A-Axis Direction Invert:
  • B-Axis Direction Invert: Ticked
  • Homing Feedrate: 50
  • X-Axis Sensor Pull-Off: 0.019690
  • Y-Axis Sensor Pull-Off: 0.019690
  • Z-Axis Sensor Pull-Off: 0.019690
  • A-Axis Sensor Pull-Off: 0.196850
  • B-Axis Sensor Pull-Off: 0.019690
  • X-Axis Position After Homing: 0.000000
  • Y-Axis Position After Homing: 0.000000
  • Z-Axis Position After Homing: 0.000000
  • A-Axis Position After Homing: 0.000000
  • B-Axis Position After Homing: 0.000000
  • Request Home on startup: Ticked
  • Request Home after E-Stop press:
==========Spindle Settings==========
  • Encoder (Pulses per revolution): 100
  • Spindle Control Method: VFD (0~10v)
  • Spindle RPM at 10 volts: 24000
  • Spin UP delay (milliseconds): 6000
  • Spin DOWN delay (milliseconds): 6000
==========Lubrication Settings==========
  • Lubricate after: 0(hr) & 10(min)
  • Lubricate for: 0(min) & 3(sec)
==========Tool Changer==========
  • Tool changer in use: 1: Manual Tool Change
  • Tool setter air blast time (ms): 0
=============X-Axis=============
  • Motor: Distance per revolution: 0.629920
  • Drive: Pulses per revolution: 400.000000
  • Maximum Feedrate: 400.000213
  • Acceleration: 19.685171
  • Travel Minimum: 0.000000
  • Travel Maximum: 48.031421
  • Backlash: 0.000000
  • Direction Invert: Ticked
=============Y-Axis=============
  • Acceleration: 19.685319
  • Travel Maximum: 48.374732
=============Z-Axis=============
  • Motor: Distance per revolution: 0.393700
  • Maximum Feedrate: 300.000183
  • Acceleration: 19.685110
  • Travel Minimum: -6.299203
  • Travel Maximum: 0.000000
=============A-Axis=============
  • Motor: Distance per revolution: 0.196851
  • Maximum Feedrate: 39.370101
  • Acceleration: 1.181103
  • Travel Maximum: 3.937010
  • Direction Invert:
  • Angular Axis:
=============B-Axis=============
  • Slaved to Y axis
==========Auto Tool Zero Settings==========
  • Auto tool zero: Disabled
==========Multi Head Settings==========
  • Dry Run: Enabled
  • X Offset: 0.000000
  • Y Offset: 0.000000
  • Multi Spindle-1 (T101): Disabled
  • Multi Spindle-2 (T102): Disabled
  • Multi Spindle-3 (T103): Disabled
  • Multi Spindle-4 (T104): Disabled
  • Laser Engraving/Cutting (T111): Enabled
  • Z Offset: 0.000000
  • PWM Freq(Hz): 4000
  • Plasma Torch (T112): Disabled
  • Oxy Torch (T113): Disabled
  • WaterJet (T114): Disabled
  • Scribe Tool (T115): Disabled
  • Pen 1 (T116): Disabled
  • Pen 2 (T117): Disabled
  • Camera (T118): Disabled
==========INPUTS==========
EStop: EStop, Invert: No
Encoder: Signal - A, Invert: No
Encoder: Signal - B, Invert: No
Encoder: Index, Invert: No
MPG: Dial Signal - A, Invert: No
MPG: Dial Signal - B, Invert: No
MPG: Select X, Invert: No
MPG: Select Y, Invert: No
MPG: Select Z, Invert: No
MPG: Select A, Invert: No
MPG: Select B, Invert: No
MPG: Resolution 1, Invert: No
MPG: Resolution 2, Invert: No
MPG: Resolution 3, Invert: No
Analog: Input 1, Invert:
Analog: Input 2, Invert:
Input 1: Cycle Start, Invert: No
Input 2: Cycle Stop, Invert: No
Input 11: Tool Setter, Invert: No
Input 12: Probe, Invert: Yes
Input 13: X - Home Sensor, Invert: Yes
Input 14: Y - Home Sensor, Invert: Yes
Input 15: B - Home Sensor, Invert: Yes
Input 16: Z - Home Sensor, Invert: Yes
Input 19: X-Axis Motor Alarm, Invert: No
Input 20: Y-Axis Motor Alarm, Invert: No
Input 21: Z-Axis Motor Alarm, Invert: No
Input 22: B-Axis Motor Alarm, Invert: No
==========OUTPUTS==========
Spindle: CW, Invert: No
Spindle: CCW, Invert: No
Output 11: Laser-Engraving (PWM), Invert: Yes
Output 18: Coolant Flood, Invert: No
==========TOOLS DATA==========
Tool-1, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-2, Slot: , 1/16" EM, Z Offset: 0.000000, Tool Dia: 0.062480, Tool Dia wear 0.000000
Tool-3, Slot: , 1/8" EM, Z Offset: 0.000000, Tool Dia: 0.125000, Tool Dia wear 0.000000
Tool-4, Slot: , 1/4" EM, Z Offset: 0.000000, Tool Dia: 0.250000, Tool Dia wear 0.000000
Tool-5, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-6, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-7, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-8, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-9, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-10, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-11, Slot: , 90 deg. V, Z Offset: 0.000000, Tool Dia: 0.375000, Tool Dia wear 0.000000
Tool-12, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-13, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-14, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-15, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-16, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-17, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-18, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-19, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-20, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-21, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-22, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-23, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-24, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-25, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-26, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-27, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-28, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-29, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-30, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-31, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-32, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-33, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-34, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-35, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-36, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-37, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-38, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-39, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-40, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-41, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-42, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-43, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-44, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-45, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-46, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-47, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-48, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-49, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-50, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-51, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-52, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-53, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-54, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-55, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-56, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-57, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-58, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-59, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-60, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-61, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-62, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-63, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-64, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-65, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-66, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-67, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-68, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-69, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-70, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-71, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-72, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-73, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-74, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-75, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-76, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-77, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-78, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-79, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-80, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-81, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-82, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-83, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-84, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-85, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-86, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-87, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-88, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-89, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-90, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-91, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-92, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-93, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-94, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-95, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-96, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-97, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-98, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-99, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-100, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-101, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-102, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-103, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
Tool-104, Slot: , , Z Offset: 0.000000, Tool Dia: 0.000000, Tool Dia wear 0.000000
  • Workoffset - G54:
  • X: 0.000000
  • Y: 0.000000
  • Z: 0.000000
  • A: 0.000000
  • Workoffset - G55:
  • X: 0.000000
  • Y: 0.000000
  • Z: 0.000000
  • A: 0.000000
  • Workoffset - G56:
  • X: 0.000000
  • Y: 0.000000
  • Z: 0.000000
  • A: 0.000000
  • Workoffset - G57:
  • X: 0.000000
  • Y: 0.000000
  • Z: 0.000000
  • A: 0.000000
  • Workoffset - G58:
  • X: 0.000000
  • Y: 0.000000
  • Z: 0.000000
  • A: 0.000000
  • Workoffset - G59:
  • X: 0.000000
  • Y: 0.000000
  • Z: 0.000000
  • A: 0.000000
  • Parking:
  • X: 0.000000
  • Y: 0.000000
  • Z: 0.000000
  • A: 0.000000
Please apply this service bulletin (skip updating firmware as you already have 5.07 on. So just do the physical motor switches, then upload the new config file for your sized machine):
https://www.onefinitycnc.com/post/service-bulletin-for-elite-masso-stepper-motor-resolution-change
This fixed the issue 100% … thanks a million!
