Motors: distance per revolution issue?
New elite foreman owner. Table build and setup complete. Have reloaded masso software and triple checked motor dip switches and still have the following issue:
X-axis only travels about 9.5” before a soft stop and masso readout says it traveled a full 48.0312”
Y-axis travels 29.7” before a soft stop according to Y readout on screen (though the “machine” readout says it traveled 48.37”)
I can “trick” it by adjusting the “Motor: distance per revolution” adjustment for each axis on the F-1 screen to move farther but don’t know what I would need to set it to to make it accurate, so I put back in the factory setting bit at least confirmed the machine can travel the full length physically.
The F-1 x and y axis factory setting are identical for M:DPR (0.62990) and D:PPR (2000) and feedrate (600) but only slightly different for acceleration. This is odd to me as the x axis is much more diminished in travel distance than the Y.
Lastly, the speed of the y axis is about 2 or 3 times speed of x axis in continuous mode.
Haven’t been able to find a solution on line…can anyone help? My heart is aching to make that first cut!
Can you please provide the Printable Settings File. See below…
Thank you for the helpful link on how to download the file. First time using forum so hope I am uploading correctly here:
MASSO Settings v5.07 (G3-20008).txt (13.5 KB)
Can you post a picture of all 4 motors dip switch positions? We’d like to compare them to what the manual shows.
As I recall, 1 and 4 are in the down position and rest are up position. I will go take a photo now and upload…
Those are correct.
Can you show a picture of your machine and show which config file you loaded?
Certainly:
That is all correct.
Can you try redownloading and reloading that config reboot and try homing?
I had just completed doing that before starting this post.
Try it again please (assuming your masso firmware is 5.07)
Thank you for your continued assistance. I reloaded the software, rebooted, and attempted to HOME. The following errors occurred (photos provided). I repeated this process a second time with the identical errors.
A homing error occurred.
After hitting the safety stop and resetting, I could jog the spindle in continuous mode. Jogging the X it moved 24” as shown in the upper left of next photo but the machine readout on right shows 48”
Jogging the Y it moved 29” but screen shows 48”
After attempting to HOME the following errors appear on F1 screen:
The x axis error clears when the stop button is reset, but the input 23 does not. The input 23 is not used. Not sure why it is red.
Any other thoughts on this today? Happy to jump on a facetime call or take my laptop in the shop and do a zoom call if that will help.
We can do some basics, and start ruling things out.
Check that all ball screw/motor couplings are tight.
Check that all homing sensor inputs are LOW in normal state.
Uncheck both Home after… boxes for now.
When you jog continuous, are the directions of movement correct - X+ > right, Y+ > to back, and Z+ > up?
When you home, are the same correct directions followed?
With the longest accurate ruler you have, measure the distance travelled in X and Y when using the MDI to command 200 mm (or some equal " value) - will depend on the length you can measure. I would put painter’s tape down on the table parallel to these axes, and measure using whatever endmill has the sharpest/smallest point. We can see if there is some consistent offset when you try differing distances.
Good and bad news. Good news: machine has finally homed correctly! Bad news: I have no reason why. Was going through the checklist sent by TMToronto and as I was measuring the various soft stop travels with the masking tape I would need to reboot (maybe 15x total this morning?) as various alarms would pop up ( sensor and motor alarms for x, y, and b but nothing consistent…random each time. (All of this after re-cabling all masso inputs). 1/3 of the time the F1 screen would show all “low”, 2/3 of the time there would be 1 or more “high” but also random as to what was high amongst the motors, sensors, and twice also on “input 23” which is blank.
Homing would not result in the “machine distance box” on the right hand side of the F3 screen to show x or y at zero (but z would be at zero). As I was rebooting and marking distance traveled before a soft stop failure to try and find some consistent ratio for the movement, on try 15 suddenly the masso machine distance zeroed correctly, and now the gantries do move the full distance. Have rebooted and it worked correctly 3x in a row now. I hate I cannot post what the “fix” was but I’m going to take the win and try and get a spoil board on and flattened today. I appreciate so much this group and the comments provided.
I have a very similar issue. I recently purchased a used elite foreman. The machine had very light to no use. However, the password for the Admin on F1 had was no longer the default password so I uploaded the software change tool from Masso. The instructions said to change update the software at the same time - so i updated to v5.13.
The machine now moves 1 actual inch for every 5 inches reflected on the screen. In other words it moves 9.625 and show the full 48 on the screen. I have verified the pitch on the axes in the program and reset several times. In the above, it appears his actual location and the location from zero did not agree, in may case they match.
Never mind. I’m stupid but figured it out.
