Max Feed Rate for Onefinity CNC
Does anyone know what the max feed rate for the Onefinity is? I’ve read that the max rapid move rate is 500 Inches per minute but I’m guessing it doesn’t cut at that speed. I’m trying to program a cutout in wood but I’m not sure how fast I can run my machine.
Hey, Thanks Chris.
I’m a complete beginner to CNC. I actually tried running it at 220 in/min yesterday thinking that going about half of the base speed was a safe cut :sweat_smile: . Don’t know if it actually went that speed but it sounded pretty bad so I stopped and did some research into how fast to run it. At the most I’ll probably ever go at ±100 in/min like what you are saying. When I get more experience I’ll try to see if it could go higher than that. I also got the post processor you mentioned. Thanks for your help.
Hey Chris - the feed rate depends on the type of end mill you are using and the material you are cutting. In reality, 220 is a decent feed rate for certain types of wood, and certainly something like Acrylic. I’ve not pushed my machine that far yet, but I do plan to and post a video on the results. Marius Hornberger recently did a rather long video on various feed rates and bits that I found fairly compelling. But there are a ton of videos on YouTube about feed rate vs materials - best to stick to folks discussing entry-level machines though, the manufacture recommended DOC and feed rates generally will not work too well on hobbyist machines. Winston Moy (via the Carbide Create channel) has some really great videos with solid recommendations - I think it’s part of “Material Monday” series. Hope this helps.
