I hope this is the correct place for this. But I’d like to setup a mister on my machinist with Makita router for some small metal pieces I want to make. Is there a write up anywhere on how to set this up so that the mister will start and stop with the job? In the event that a job finishes and it takes me 10mins to go shut everything down I don’t want the mister flooding the workspace nor wasting the coolant/lubricant.
I use the Load outputs on the back of the BB controller (although 1F doesn’t support them and says they are inop, mine work fine) along with the following to control mist cooling on my Journeyman…
works fine, just be sure to include the code to turn the mister on and off. Can be used without cooling as a directed blower also, just be sure to run it dry for a few minutes to purge the coolant.
Let me know if you would like pics of my mister setup.
Hope this helps…
