Modifying number of passes
Hello friends,
Brand new CNC owner and I have a question I was hoping to get some help with.
I have an X-50 and am using the included subscription to Carveco maker.
I have it cutting what I want, but now how I want. I’m basically machining channels into flat material, and I need it to make one pass at a specific depth. Currently it’s making multiple passes which doesn’t work.
Like I need one pass at five millimetres deep, rather than five passes at one millimetre deep.
Is there a way to adjust this? I can’t seem to find it under the tool path or tool settings.
Please and thank you.
Im not a Carveco user but when you select the tool the should be a depth per pass setting. Sounds like you have it at 1 mm. Crank it up to 5mm and then when you create the toolpath with that selected tool it should show 1 pass instead of 5. Im assuming its similar to vcarve.
Good luck
Thanks for the answer Robert!
I see a setting called step down, which is I’m assuming what you mean. So I’ll increase it to the depth I want and hope that does it.
