just thought i would drop a picture of my setup now that it is working correctly.
Looks busy.
I see your table is mounted on casters. Do you find that sturdy enough when the spindle races across the work surface? My bench is flat on the floor and bound to the wall behind it, and still shows some shuddering. I was thinking, though, that having it on casters would be better for maintenance. Having it fixed has been a right old pain when applying upgrades, as accessing the steppers is very difficult.
yes so far no troubles at all same table i have used for several years both for the older build botics journeyman and now the elite JM. they are very heavy duty. https://www.amazon.com/dp/B07TYL2G87?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_8
