Has anyone installed leveling casters onto their Kreg table? I will rarely move the table but want that flexibility as my shop evolves. The good ones are expensive, roughly $60 each/ 240 set, but would do it as long as they don’t introduce much wobble. There are many others on line at wildly varying prices but I just don’t know the quality. Like these: Leveling Casters | 2" Wheel with Ratchet Adjustment and 1/2" Stem Mount – Leveling Caster Store
Check out these; maybe they could be attached to the Kreg table legs and be used to lift the feet off the ground when you want to move the table.
I have seen these before but have not considered them, could be a solution. I will wait for my table to arrive and see if the holes in the feet can work with the table legs. One concern is you have to lift the table at each end to change from base to wheel, and once the entire table is done with storage and machine, it will probably be over 600 lbs. But there are small hand jacks (Dewalt, Irwin) now on the market that could easily do this for the few (if any) times I move the table. Thanks for the suggestion.
Kreg tables suck with casters, Legs just bend. Build a real table
Well, what is a real table?
Looks good. I like the vertical milling option. Looks like you have leveling feet on it? Do you have any plans you would share? Thanks.
I don’t have a Kreg table but have installed that style of leveling casters on many of my shop tables because I have an unlevel garage floor. I got larger 3" wheels from Amazon, and are very happy with them. W B D WEIBIDA Industrial Grade Leveling Casters Set of 4, Heavy Duty Retractable Casters Wheels with Upgraded Ratchet Arm 6600 LBS, Workbench Casters with Nylon Wheels & Leveling Feet for Machine: Amazon.com: Industrial & Scientific
I installed a set on my Kreg table thi week. A little less “shake” but it was not eliminated. HOLKIE Leveling Stem Casters Set of 4 Heavy Duty Retractable Caster Wheels, 1/2" and M12 Stem Size, Total Capacity 3300 Lbs, Adjustable Wheel with Ratchet Handle for Workbench, Machine, Equipment: Amazon.com: Industrial & Scientific
