Need help with Z axis calibration
Hi folks. I seem to be having an issue with my Z axis. The head is cutting .02" deeper than programmed. I’ve run various tests and have discovered this measurement of .02 to be fairly accurate. Herewith is a screenshot after homing the machine. I’m running a Journeyman model purchased in 2022. Any advice would be greatly appreciated. Thank you!
Check your probe measurements.
Not sure I understand. I use the probe that came with the machine to probe XYZ
Here is how to calibrate the probe. If you havent calibrated it, it is very likely you need to.
