New Z Motor with brake Installed - Works great!
Elite foreman 4x4 with water cooled spindle. Install was even easier than the instruction video.
This is what I did, your experience may be different.
  • Unlugged power cords
  • Removed the cover and plugs
  • Did not remove the spindle just shimmed the z axis up to get the coupler to align with new motor coupler.
  • Had the new motor just sitting loose with its half of the coupler tightened on the motor shaft so I could see the alignment needed until it aligned.
  • Did not remove z axis half of the coupler. Double checked the coupler engagement depth with the motor in place then tighten up the motor mounting screws.
Brake works great.
One thing I noticed is the cover mounting screws on the new motor are black and the old motor is silver. That should speed up the Z axis at least 20 percent… :stuck_out_tongue_winking_eye:
Low drag screws yea :wink:
