Howdy all you very smart folks!
Easy question, but say I had two tool paths calculated (VCarve Pro) and the program thinks it is two different bits. Once the first cut path is completed, then the 2nd file is started but I actually leave the same bit in, do I still need to re-zero the Z axis? I’m actually doing this on purpose to trick the machine to cut a little further out then 32x32.
Thanks in advance!
