Onefinity CNC Firmware 1.7.1 BETA 1 (10/7/25) (X-35/X-50/Pro machines w/ BB Controller) (BETA Firmware))
10/7/25
For Original and Pro Series BB Buildbotics controllers
THIS IS BETA FIRMWARE. DO NOT INSTALL THIS ON PRODUCTION MACHINES.
IF YOU DO NOT HAVE AN EASY ADAPTER / BB ATC WE DO NOT RECOMMEND INSTALLING THIS BETA FIRMWARE. IT WILL NOT ADD ANY NEW FEATURES, PERFORMANCE ENHANCEMENTS OR FIX ANY BUGS.
1.7.1 BETA 1
  • ADDS: Support for Easy Adapter
  • ADDS: 90 Second Delay for Easy Adapter Boot up
To enable the easy adapter, go to the fly out menu, click settings, find the ‘enable easy adapter’, and click the check box. This will add a 90 second countdown when booting up the machine, which is the time needed for the easy adapter to boot up correctly.
Update file. :right_arrow: Download 1.7.1 BETA 1 Here (3.4 MB)
(You must be logged into the forum to download)
How To Install:
  • Updating via WiFi
    Wifi:
    If your controller is connected to your home internet, the controller will automatically find the update. At the top center of the screen the words: upgrade to 1.4.0 underlined in blue. Click that. Click update via web button and let the system do it’s thing.
  • Updating via USB
    You’ll do an update via USB using the following steps:
    After downloading, DO NOT UNZIP THE FILE!!!
    Copy the blue .bz2 file above onto a usb stick (it must be formatted as fat 32 or ntsf). Click the flyout menu (three bars on top left), general, under firmware click ‘UPLOAD’. Select the 1.7.1 file.
    If you are on firmware 1.0.8 or lower, it may ask for a password.
    the password to update will either be buildbotics or onefinity
:alarm_clock:Very important NEW step. You MUST turn off rotary mode to update. If rotary mode is turned and when you do the update, the configuration values for the A axis will get stuck and not install correctly.:alarm_clock:
Manual on updating
Interesting this adds Easy Adapter support. I was previously told it had been discontinued for BB machines, does that mean it’s coming back?
No. This is for the handful of customers who have the easy adapter.
The easy adapter is discontinued permently along with the bb controller and it’s firmware development.
