Onefinity ATC Testing Data Summarized (Full PDF below)
Test Areas
- Collet Nut Clamping Torque
- Endmill Movement/Security Between Tool Changes
- Effectiveness for Real-Life Machining
Test Equipment
- Precision calibrated digital torque wrench (KTC GEK085-W36E)
- ER20 collet nuts and collets (1/8”, ¼”, 3/8”, ½”)
- Endmills from Cadence Manufacturing and Design
- RapidChange ER20-6 Premium magazine
- 80 mm ER20 1.5Kw 110VAC Spindle
- Onefinity Eazy-Z Tool Setter
- RapidChange ATC parameters
Test Procedures
- Used the ‘first movement’ test method.
- Tests replicated 10 times for tool assemblies.
- Two sets of tests: 4 endmill sizes and six ¼” endmills.
- RapidChange ATC Desktop App settings: Load RPM 2400, Unload RPM 2600, Engage Feedrate 1900 mm/min, Number of loading plunges 2.
- Tool offsets measured before and after tool changes.
- Combination of O-rings and Onefinity’s tool retention system used.
- Tool offset values measured before and after machining.
- Adaptive clearing toolpaths created to machine rectangular pockets.
- Hard oak slabs used for all tests.
Results, Observations, and Conclusions
- No recorded tool load failures in hundreds of tests.
- Collet Nut Clamping Torque:
- Minimum torque: 12.7 Nm
- Maximum torque: 28.9 Nm
- Mean torque values for six ¼” endmills: 21.58 Nm, 21.26 Nm, 20.21 Nm, 22.95 Nm, 15.21 Nm, 21.67 Nm.
- Mean torque values for 1/8”, ¼”, ¼”, and 3/8” endmills: 15.17 Nm, 16.8 Nm, 14.95 Nm, 17.25 Nm.
- Endmill Movement/Security:
- Minimum offset difference: -1.46mm
- Maximum offset difference: 1.42mm
- Most differences less than 0.5mm
- Mean value: -0.025mm
- Effectiveness for Real-Life Machining:
- Minimum offset difference: -0.05mm
- Maximum offset difference: 0.04mm
- Most differences less than 0.01mm
- Mean value: -0.004mm
Data Graphs:
Complete Findings included in PDF form below
Onefinity CNC Easy ATC by RapidChange Test Data.pdf (140.4 KB)
