Onefinity Elite CNC (Masso) | How to trigger the router and vacuum relay power ports automatically (FAQ)
In this video, Stone walks through how to use the Onefinity Elite series router and vacuum relays. He shows to to manually turn them on and off an automated them as well with Gcode programming.
Notes:
The VAC port is for 12amp or lowers vacuums.
The ROUTER port if for the Makita (or similar) routers. DO NOT PLUG IN A VFD/SPINDLE INTO THIS PORT! VFDs MUST be plugged into wall power.
GCODE:
ROUTER port enable: M3
VAC port enable: M8
TURN OFF: M9
BUTTONS:
(tap once to turn on, tap again to turn off)
ROUTER : Spindle CC
VAC: Coolant Flood
