Onefinity Journeyman X-50 CNC (48"x32" Cut Area) with Accessories and Add-Ons (Phoenix, AZ)
The CNC machine and spindle has been used for a small number of cuts and the condition is like new. Selling for $3000. I live in Phoenix, AZ. The set includes the following:
• Includes Onefinity controller
• Large ViewSonic Touch Display (connects to controller to control the machine)
• 80mm clamp and 60mm clamps for the Z-axis
• Extra stepper motor wires o Onefinity 3-Axis XYZ Touch Probe
• PwnCNC V4 dust boot
Huanyang 110V 2.2kW VFD spindle package:
• VFD (variable frequency drive)
• 80mm ER20 water cooled spindle motor
• VFD 2 meters Extension Cable & Box for keypad Control Panel
• 14pcs ER20 collet set
Variety of bits:
• SpeTool Carbide Spiral Router Bits Up & Down Compression Bit, 1/4 X 1 inch Cutting Size with 1/4 inch Shank
• SpeTool 8Pcs Carbide CNC Router Bits Set, 1/4 Inch Shank for Woodworking, Detail Carving, Trimming, V Groove Engraving, Slotting Mortise
• Newdeli 90 Degree V Groove and Round Nose Bit, 1/4" Carbide
• Surfacing Router Bit, 1/2 Inch Shank Slab Flattening Router Bit Carbide Tipped Surface Planing Bottom, Cleaning Cutter 1 inch Diameter Planer Bit
• Genmitsu 40pcs End Mills CNC Router Bits, 1/8" Shank CNC Cutter Milling Carving Bit Set Including 2-Flute Flat Nose & Ball Nose End Mill, Nano Blue Coat & Titanium Coat CNC Bits, MC40A
• SainSmart Genmitsu 10Pcs Nano Blue Coat Flat Nose End Mill CNC Router Bits, 1/8" Shank Spiral Upcut Single 1 Flute End Mill Set (3.175 x 17 x 38mm)
This topic was automatically closed after 30 days. New replies are no longer allowed.
