My daughter is making flower box crafts, and I already used my tangential knife to cut the square foam core backings to fit the Ikea picture frame boxes she is using. Today I saw her marking an array by hand on the squares in order to neatly lay out the arrangement of the flowers before gluing. It was a tedious and time consuming job.
I created a quick file in F360, then loaded it into SheetCam to modify the order that each dot would be made, and to set up the g code file.
I attached the marker holder I designed for the 65mm mount and ran the program. We can now accurately create this array template, and others, saving her a lot of time.
