Have you tried it ?
Pat
No time yet but plan to - watched a few video reviews thus far is all. Currently I am fully invested in Fusion, and I would miss the seamless CAM.
If it doesn’t do CAM, than it’s not an alternative to Fusion.
I went ahead and downloaded it and so far pretty impressed. I mainly use it to model for 3D Printing, geometric stuff, clamps brackets and so on. I expect it will have CAM sooner than later, time will tell. Much fatter learning curve than Fusion for me anyway.
Pat
Appreciate the reply and insights. Are you using Fusion currently?
No I am not, we were early adopters with Fusion al long time ago, and my shop does still use it for all the parts modeling but not for CAM, we use Sufrcam for that. I retired bout 6 years ago and used fusion at home for a while, just looking for something free that is easy to use for as I mentioned 3D printing fixtures , clamps and so on.
Pat
Pat, the point about the learning curve is useful to hear, since I’m mostly curious about simple 3D-printed fixtures and brackets rather than full CAM. Given that you already have SurfCAM covered in the shop, it sounds like the open-source option fits the home/hobby role well. Do you find it handles those geometric clamp and bracket shapes without much fiddling, or does it take workarounds? That’s the part I’d want to gauge before committing time to it.
I have not had to do any fiddling with any of the things or workarounds for what I have been doing, again, pretty simple geometry. It’s free you do not have to register, just down load and start to use it, very easy to try, plus there is a lot of tutorials on YT for beginners.
I have tried a lot of the free stuff, this one to me is hands down the winner, I do have experience with Fusion and it is a lot like Fusion so that may have played into it for me.
I had been using the free version of OnShape and it was OK but I like this one a lot more.
Pat
Pat, the comparison to Fusion is the detail that matters most here for me, since you already know that workflow and still prefer this one. The fact that simple brackets and clamps need no workarounds is reassuring, though it sounds like more complex geometry might be a different story. Free with no registration makes it low-risk to try, which helps. Good to hear OnShape was workable but this suited you better, that gives me a useful reference point.
Pat, your point about the Fusion comparison lands for me too, since a familiar workflow cuts the learning curve a lot. The reassurance that basic clamp and bracket shapes don’t need workarounds is what I’d want before investing time. I’d be curious whether the tutorials cover the simple geometry you’re doing or mostly general modeling, since that affects how quickly someone new could get going. Free with no registration really does lower the stakes for trying it.
There is a program called FreeCAD that I just recently learned about (I have seen it mentioned several times on LinkedIn). I downloaded it & poked around in the interface a bit. It appears to be a nice clean interface, and has a CAM workbench. It looks quite promising, and I hope to eventually learn more about using it. It supports part modeling, assembly modeling, and CAM. Since my work is primarily 2D & 2.5D in nature, I currently use 2D CAD and Estlcam, and I’ve never cut a 3D chip on my machine yet, other than V-carving. I hope to dip my toe into 3D at some point, but will need to dedicate some time to learn FreeCAD & its CAM workbench.
I’ve used Fusion at work, but have not found myself very fond of it. The workflow is just different enough from Inventor and SolidWorks that it seems foreign to me.
Still a ways to go but I’ve started working on CAM software.
